anyone tell me how the drive coupler connected to the crank shaft comes off? i spun the splines on my drive shaft and cant tell what the splines are like in the coupler.
how to remove polaris drive coupler????
Re: how to remove polaris drive coupler????
My Clymer manual (1992-95) says to turn the engine until the #3 piston is almost top dead center then turn clockwise until the piston moves about 1 inch down in the cylinder. Then insert 1 foot of 5/16 nylon rope into the cylinder through the spark plug hole leaving some of the rope outside the engine. Turn the rear coupling counterclockwise to remove.-The coupling is supposed to have flats, in order to put a wrench on it--Hope this helps.----Let us know how this turns out......
