Yesterday the ski ran okay for a few minutes then could not get it started again. Today pulled the plugs and it turned over fine but with plugs in it is real slow if no turning at all. I have the battery on a 2v trickle charge and it is on the green. Ia this the starter or what?
PLEASE HELP Will turn over without spark plugs in but not with them in?
85 Kawasaki JS550
http://www.cardomain.com/id/thegraytta
"Keep your nose out of the sky
Keep your heart to God
Keep your face to the Rising Sun"
Tags: None
Re: PLEASE HELP Will turn over without spark plugs in but not with them in?
Originally posted by David3aceswith plugs out, try to trun engine over by hand...use flywheel on rear of engine...does it bind while turning?
85 Kawasaki JS550
Alright i turned it by hand and it turned very smooth. The motor had excellent compression. So does that mean its the starter or battery or what?
85 Kawasaki JS550
I tried to do a comp test but it does not have enough power to turn over the motor with the starter. What should I do?
85 Kawasaki JS550
Well first check your battery or jump with another 12 volt battery with jumper cables, if it turns over replace battery. Did you try yet to see if you can turn the motor over by hand with the plugs out, under the coupler cover you should be able to reach in there and turn it.
yes I turned it over by hand and it turns fine. The motor is not locked. The only reason i think the battery is fine is that it reads a full charge on the trickle charge.
85 Kawasaki JS550
I MIGHT HAVE FOUND IT!!! Well i took the seadoo battery out of the spi and put it in my Kawasaki ski and the kawasaki acted the same way and turned over very slow and eventually nothing. So does that mean the seadoo battery was bad and that was my problem?
85 Kawasaki JS550
Originally posted by minsportSounds Like It, Yumikron Batteries Will Last 3 Years If Taken In And Charged In The Off Season.
85 Kawasaki JS550
