Re: got a rope caught up in intake
the tow in is most likely where the water came in you need to get it completley out of water continue to crank itt ill you get as much water out as possible then put in new plugs and try to get it started keep trying with new plugs until you get it started once started you need to ride it for a good 30 minutes hard to get the moisture out of it. It will be okay to start it out of water but dont run it too long while it is out.
BTW you probably dont have as much damage as you think it may just be the water in the engine which if taken care of now will be minimized.
