Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    Jul 2005
    8
    Default got a rope caught up in intake
    my wife was riding our 99 gsx and got a rope caught up in the intake.
    she shut the ski down, right away, when i got out to the ski and took off the grate, the rope was wrapped around the shaft pretty tight.
    i removed everything i could se, the shaft is now clear as well as the prop.]
    i cant see any further up into the shaft area from the outside of the ski.
    the problem, it wont start, just makes a clicking or clunking noise now, and the battery is brand new and i recharged it just to make sure.
    one time trying to start it, it did sound like the starter was going to go, it turned about 3 times, but just keeps clicking.
    is it possible there is more rope where i cant see, that would be making it not want to turn over and if so, how do i fix it??
    thanks for any help
    99 gsx
    Jul 2005
    8
    Default Re: got a rope caught up in intake
    i do see where others have posted about a rope being sucked up, and see where it might be a bent shaft.
    i was just wondering if there could be any other rope where i cant see, up near where the shaft goes into the ski, not near the rear of it where the prop is ?
    Nov 2003
    Glendora, CA
    6,846
    One of two things probably happened.
    The impellor is still stuck with rope or debris around it or she burnt up the solenoid trying to start it.
    Using a flashlight, you should be able to see anything in the pump if you look from both ends hard enough. Look closely at the rear of the impellor for something caught between the impellor and the pump vanes.
    If she burnt up the solenoid, replace it. Make sure your battery is charged. Remove the sparkplugs and use the starter to see if maybe you flooded the motor with water when towing it back to shore if you did that.
    Jul 2005
    8
    there is no rope around the impeller, but i did notice the engine area fills with water, while it is sitting with the drain plugs in now.
    the starter and solenoid i believe are working properly, as it did turn over a couple of revolutions while trying to start it, most times just makes a clicking noise like its bound up.
    could the shaft be bent enough to let in water and keep it from starting?
    when i take out the shaft, will i beable to tell how bent it is ?
    its still in water, as i have no way to get it to the dock. on my beach area.
    Nov 2003
    Glendora, CA
    6,846
    You need to get that boat out of the water and get it started up. I think it is bound up allright, with water in the motor. It is called Hydrolocked. DO not try to start it again with the sparkplugs still in it. If I am right, you can do damage to it if it is hydrolocked.
    If you do not fix it now, and it is full of water, you will be buying a new motor.
    Once you have got it running, you can deal with the damage to the driveshaft and seal later. You will need to remove the pump and the driveshaft and seal and inspect all of those pieces. If the driveshaft is bent, you will notice it when you roll it across a flat surface.
    Jul 2004
    Ft Worth Tx
    1,095
    if it is leaking while sitting I would say you have mesed up the seal where the drive shaft goes into the hull I would get it out of the water and get it to the shop or you yourself can start working on replacing the seal and the driveshaft and possibly rebuilding your pump as you may have messed up the bearings there too.
    Jul 2005
    8
    ok, so even if the shaft is bent, it still should start ?
    the shaft can't be bent enought to cause it not to turnover ?
  8. #8
    Jul 2004
    Ft Worth Tx
    1,095
    probably not but if you have pump bearings that are frozen that will prevent it from being able to start the way for you to tell is to pull the pump and confirm it is the engine.
  9. #9
    Nov 2003
    Glendora, CA
    6,846
    No I have never seen a bent shaft stop a motor from turning over. I think there is a good chance the motor is water flooded. I am about to post some pictures of a Sea Doo GTX that sucked up the tow line into the pump. You will not believe the damage to this ski. It is by far, the worst I have ever seen.
  10. #10
    Jul 2005
    8
    ok, thanks for all the info.
    im not sure where the pump is or how to get to it, guess i should go buy a repair manual.
    thanks.
    also, the engine gets flooded with water, and by removing the spark plugs, will release this water ??
  1. help! got rope caught around shaft
    By pwint in forum Sea-Doo
    Last Post: 10-25-2007, 12:05 AM
  2. Replies: 1
    Last Post: 09-04-2006, 04:53 PM
  3. sucked up rope and filled with water
    By mecjr22 in forum Polaris
    Last Post: 08-10-2005, 03:43 PM
  4. Replies: 6
    Last Post: 07-18-2005, 10:45 AM
  5. rope caught in impeller
    By cultuslake in forum Sea-Doo
    Last Post: 04-17-2004, 09:52 AM
