After almost a month of waiting in line my jet ski has finally been looked at & the sea doo mechanic thinks the problem is the rotary shaft. He is gonna give me an absolute diagnosis in the next couple days. The jet ski will turn over but it won't crank all the way because it is not pulling any gas. Anyways, I saw on here that the rotary shaft itself is only $150, but does anyone have a guess as to how much the total job might cost me. I am sure they gotta take the engine out & who knows what else. Thanks for your help.
1999 Sea Doo GS Rotary Shaft
Re: 1999 Sea Doo GS Rotary Shaft
at the dealer you will prob get a 4 to 5 hrs bill x there rate , i can look up the flat rate later , thats somthing everyone should know is the flat rate for the jobs they need , ive seen some 5 hr bills for 2 hr jobs and if you dont know or they dont explain why they needed extra time , there ripping you offPRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
A rotary valve shaft and gear never fails without some other reason for it to fail.
Typical causes in order of most common first:A bearing has failed in the motor and jammed the rotary valve.
A foriegn object has gotten caught in the valve, other than a bearing. Like a screw dropped down the carbureator.
The oil lines are dry that feed the RV cavity.
They just do not "wear out".Bill O'Neal <br>
I can save you some money on the rotary valve shaft but that is about it. I sell the shaft for 100 complete with the brass gear if you need one email me at installer_man@yahoo.com also you see the price here on SBT but that is not the price the dealer is going to give you for his shaft (LOL) anyway no you are actually looking at maybe a 350-600 bill with parts depending on the shops labor rate.
