Results 1 to 10 of 10
    May 2004
    10
    Default 99' SPX Idling Problems
    I just rebuilt my carbs and installed all to factory specs, low speed adjuster 1.5 turns out, high speed 0 out and the ski runs great but I am having idling issues. If I set the ski to idle at 1500 on the tiny tach in the water then it revs up to 3500 out of the water. So then I turn it down to 3000 out of the water and it only idles at 1000-1200 in the water. I would be fine with the first scenario but then when I flush it out the motor wants to diesel and not turn off from idling so high. Any suggestions?
    Jul 2004
    Ft Worth Tx
    1,095
    Default Re: 99' SPX Idling Problems
    run it down to about 1400 or so and see what you come up with out of water that may be something you can live with.
    May 2004
    10
    Thanks... I sure I could do that but I guess I am anal about my ski and just want to know if I did something wrong in the rebuild process or do I have other issues, like air leaks.
    Jul 2004
    Ft Worth Tx
    1,095
    when you rebuilt the carbs did you pop off and pressure test them the only other thing is did you use new gasket on carbs when reinstalling them.
    May 2004
    10
    I did test each carb for the pop off pressure and they were both about the same, only maybe 1 psi deviation, but I can't remember the psi. I know the factory calls for between 36 and 40 so I guess I am somewhere around that #. Have you found success at a particular psi?
    Jul 2004
    Ft Worth Tx
    1,095
    I usually use the lower end of specs I was asking because you said you were concerned about air leaks so I stated what could have been wrong for the service that you had done. pop off and pressure test as well as carb gaskets.
    Jul 2004
    connecticut
    92
    it doesnt sound like you have much of a problem to me... set it at around 12-1400 rpms and it should be around 2500-3000 rpms out of the water thats pretty normal from what i read
  8. #8
    Nov 2003
    Glendora, CA
    6,846
    All you need to do is slightly richen the low speed adjusters.........
  9. #9
    May 2004
    10
    Bill,
    So that I know how to diagnose future problems....why did you say to richen the low speed adjuster, just curious? Thanks
  10. #10
    Aug 2001
    Las Vegas, Nevada
    1,220
    Bill said to richen the low speed adjusters because the engine is very lean at idle, this in turn causes the RPM's to increase quickly until the engine diesels (or glow-plugs as some call it). By adding additinal fuel via the low speed adjusters, you richen the mixture and avoid the whole scenario of over-revving on the trailer.
    John Kubiak
    Las Vegas, Nevada
    Sea-Doo Tech 13736
  1. 97 Spx Problems Please Help
    By paintballguy in forum Sea-Doo
    Last Post: 07-08-2006, 08:32 PM
  2. 1996 spx starting problems
    By andsparks in forum Sea-Doo
    Last Post: 08-06-2005, 10:52 AM
  3. 1996 spx starting problems
    Last Post: 07-20-2005, 10:40 AM
  4. Replies: 2
    Last Post: 06-01-2005, 04:25 PM
  5. 97 SPX Engine Problems
    By JimZ in forum Sea-Doo
    Last Post: 05-21-2003, 10:10 PM
