97xp no start,fuse in top position has no voltage,in /out
97xp 12v not
Re: 97xp 12v not
all is dry. i have no idea on terminal & fuse designation in referance 2 fuse (7.5a) in top position ...no v @ either side of fuse . lanyard on no beep ....lan on push strt button -one beep -no v @ start sol i do have basic skills (diag.-trbl sht) i could really benefit from a schm. & system overview.....i appreciate your time. or diagnostic flow chart ..... what are the required components to make this unit engine get spark???my knowledge on this magneto thingy and related has never been xplained 2 this 39 year old as you would an 8 yr. old .I cant wait 2 learn some new stuff!!!!!
Re: 97xp 12v not
if you get a single beep with the key on , its possable that you just need to get the key programed to the ski . when did the problem start ?
a quick test to check if most is working is to jump the relay . its in the little black box in the front next to the engine . if the engine cranks from there then you shoul dhave a bad relay or with one beep it could be the key is not set to the mpem .PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
Re: 97xp 12v not
the unit does turn over when solenoid (relay,?,,, i will refer 2 it as solenoid) is bypassed or jumped
.. i pierced solenoid trigger wires and could not aquire voltage...... will you please excuse
my p.c./keyboard skills /( lack of )!..
i need 2 know if this pwc is a p.o.s.........I am about 2 bypass this unyielding device.(memw..?????interlock??? ) Is there anyone out their whom might be so kind &
help speed this process up ? where and what 2 jump...cut ....discard ...delete....
