gasket kits?
  • gasket kits?
    I'm coming up to get a crank from you guys today and I was looking at your gasket kits. What comes in your internal and installation gasket kits?
    Internal is the crank end seals, head and base gaskets. Installation is the intake, exhaust and flywheel cover.
      thanks, forgot to mention this is a 787. Does the internal kit come with the oring that goes on balance shaft cover?
        Yes it comes with all internal o-rings - the Internal kit is everything to build the block.
          sweet, thanks. See you guys in a bit. :D
            :( the kit was shy the oring I was refering too. O'well I'll get it when I order my piston kits.
              You sure? I just looked at some on the shelf and they all had one...
              I've got one here waiting for you regarldess.
                yes positive. the kit I got had oil seals for crank and rotary shaft, o ring for rotary shaft, orings for rave valve, cylinder and head orings, base gasket, and rave valve gasket, and the red oring that goes on pto end of crank. That was all I got in the kit. which means the only thing missing is the balance shaft cap oring.
                edit: Thanks, I'll swing by tomorrow when I take my doo out. Who should I ask for?
                  What's that?
                    the oring that goes between the distance sleeve and the brass gear. It's just slightly larger than the orings for the RAVE valves.
                      OK, gotcha. I pulled a production kit, which omits that since the shaft assemblies are already complete. Our retail kits have it.
                      Ask for Bryan. If I'm unavailable, the o-ring is on my desk, anyone can grab it.
                        Got the oring today, thank you much. You guys are awesome, even the guy at the counter is extremely friendly. :D
                        Daryl
                          Anytime, sorry it wasn't in your kit!
