Took the boat out this weekend and ran into some problems.
First half of the day the boat ran fine. Later on we started hearing a ticking sound so opened up the engine compartment and it sounded like a rock tumbling around in a can. Let the engine just set and idle for a little bit and the sound would go away.
At the same time we found the engine wouldn't stay running unless you pushed the throttle up so I turned the idle screw up and that seemed to work but the engine is kind of sluggish getting to full power.
Next we started noticing in a hard turn the engine would lose RPM and then jump back up after you straightened out.
Last run of the day taking it back to the dock it ran fine except for the sluggish throttle response. Got to the dock and had to wait for the crowd ahead to get their boats out so shut down the engines and when I went back to start it, it wouldn't start. Changed the spark plug and it started for a few seconds and then no start after that. Engine turns over just fine though.
Any ideas would be greatly appreciated.
We are considering just ordering a new engine but not sure if I want to do that yet.
