can't remove impeller from shaft
  • can't remove impeller from shaft
    thanks for the tips so far, i got the impeller tool and with the end of the impeller shaft in a vice using a very good mac 1/2 inch impact gun set on counter clockwise {lefty lossey} can not get impeller to come off ,soaked the inside of impeller with pb blaster any tips. thanks
    Re: can't remove impeller from shaft
    I didn't have any luck with my impact gun, ended up using a breaker instead...
      Heat.
      If you knew,then you'd know!
        yes heat up heat it up so that the loctite loosens up to let it off.
