Results 1 to 8 of 8
Thread: Battery issues
  1. #1
    Joined
    Jun 2005
    Posts
    47
    Default Battery issues
    I had just taken my waverunner out, and after having to start it up a few times the battery will die on me..the battery we new this summer..wondering what could be the problem
  2. #2
    Joined
    Nov 2003
    From
    Glendora, CA
    Posts
    6,846
    Default Re: Battery issues
    You probably need a new rectifier so the battery can be charged while running.
    Bill O'Neal <br>
  3. #3
    Joined
    Jun 2005
    Posts
    47
    First where is it located...second what price am i looking to pay and last would i be able to put it in myself..thanks
  4. #4
    Joined
    Jun 2005
    From
    California
    Posts
    38
    First of all how long have you owned this PWC? then have you checked the water leve in the battery? Check the connections to make sure they are not loose or corrded. Check the ground on the starter to make sure it has good connection. The other check is using a multimeter and jumper cables. Try hooking the pos leads on the cable to the battery pos and pos cable. Start the engine and remove the jumper from the battery if it dies then you need a new magneto assembly located in the front of the engine which usually requires you to remove the engine. If it does not die then check with multimeter to see if the charge is 12-14vdc or what ever your repair manual says it should be. Most likely unless you have had to change out the starter or hear something knocking around in the fly wheel cover area, most likely it is a bad connection in the electrical area or def battery.
  5. #5
    Joined
    Jul 2004
    From
    Ft Worth Tx
    Posts
    1,095
    to test the rectifier start ski rev to 5000 rpm check voltage at battery if not between 13.1 and 15 replace rectifier.
  6. #6
    Joined
    Jun 2005
    Posts
    47
    Quote Originally Posted by gunbunny316
    just got back from vacation the other day and right before the battery died it thankfully turned over and started..i then rode it around for a good 45 minutes..the motor didnt die so im guessing that it might be just bad connections..i will go check that out
  7. #7
    Joined
    Jun 2005
    Posts
    47
    okay just checked all connections..they're all good but when i checked the fuse going to the rectifier looked fine but i found little orange droplets inside of that fuse..should i replace that fuse and could that be the problem?
  8. #8
    Joined
    Jun 2005
    From
    California
    Posts
    38
    was the droplets hard or wet, could be a little corrosion or it could be due to current almost causing it to blow. use an ohm meter to check it. I would suggest replacing it. The cost is only 20cents :emoticonc but thats not it I sugest try unconnect some of the conectors and reseating them, might have a bad connect and thats all it needs. Intermittant problems are always hard to find. Connectors are tricky even though you can snap them in If the male and female pins do not touch just right a cold or hot enviroment can cause them to loose contact. Also make sure they have a dialectric grease in them to prevent water from entering and keeps them sealed and dirt free.
Thread Information
Users Browsing this Thread
Similar Threads
  1. 97 GTX 12 volt low & dead battery
    By trent1NY in forum Sea-Doo
    Last Post: 07-23-2007, 11:37 AM
  2. Battery Drain down over 4 days?
    By Denali in forum Sea-Doo
    Last Post: 06-26-2007, 08:25 PM
  3. Battery or Starter
    By mhmcleod in forum Yamaha
    Last Post: 06-30-2006, 12:39 AM
  4. SeaDoo just clicking - low battery?
    By bamboo in forum Sea-Doo
    Last Post: 07-26-2005, 02:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
