My engine start after some time but when it got into water it choked and died.:emoticonr
After much hazzle I got it to start again but died right after .
Tried low adjuster from 1 turn out to 2 turns out , I can get it to start but it eighter dies or wont go on idle . I tried and I tried till the battery went flat and we towed it to the boat house and tok the battery out to get charged .
The plug cap on coilwire is worn and to short to cut for new cap and fresh wire.
New coil comin up.
Then I have the carburator just cleaned it , no new parts.
Rebuild kit , is there just one standard rebuild kit?
Is there any parts behind rotor that in know to cause trouble?
Compresion is 152 PSI on both cylinders. New bore and pistons .25
Can I give up trying to fire it up without new parts or can I try firing it up as it is now and keep on adjusting ?
Ohhh... help me Obi Wan ....
New coil comin up.
