Does anyone have a diagram of were all the tubes go? I have a Tube that has a T in it neither sides of the T are connected the end of the tube with the T in it is located above the water baffles water injector it is not connected to the water injector and the water injector is connected. The tube that the t is in runs around the back of the hull to the side by the carbs it hooks into what I think is a soilinoid and the soilinoid has to hoses that come out of it one runs to a black box thing on the carbs. the other hose goes somewere else. All these hoses are BLACK. Also there is a clear thin hoose about the same thickness as those black hoses that is above the drive shaft after the motor just laying there not connected it is not long enough to plug into the T there are no other hoses that i can see that are not connected but i may be wrong....
Diagram, Pictures, Drawins ANYTHING please help
