I just replaced the motor with a complete engine from SBT and I have encountered some problems. When I get the engine to start it will not idle or take throttle. I have checked everything I could think of and even replaced the fuel pump to the 780 model. I messed with it a little today and have discovered something weird. I can adjust the idle enough to keep it running and then proceed to remove plug wires and this is what happens. When I remove the back plug wire nothing changes, when I remove the front plug wire nothing changes but when I remove the center one the engine dies. This is the same result whether I have the front and back plug wire off together or just remove the center one only. Now I have checked for spark and it is all there and I can hear it when I removed and put the plug wire back on.The spark looks the same on all 3. I have replaced the plugs with no change and I have done a compression check and they are all above 100. What is my problem?
Scott
Scott
