Results 1 to 3 of 3
    Jun 2005
    Virginia Beach
    9
    Default Rotary Valve Timing
    I'm sure everyone is getting tired of the same old question, but my ski is a little different. I have a 92 SP, but the previous owner replaced the engine with a 95 657, twin carbs and stainless steel prop. I just recently replaced the engine with the same size from STB. I've heard it is not the engine but the model that ditates the valve timing. With a complete seperate setup, I don't understand what the model has anything to do with it. My rotary valve cover number is 810 038, if that helps. I'm confused between 130 or 147?
    Aug 2001
    Las Vegas, Nevada
    1,220
    Default Re: Rotary Valve Timing
    It IS the engine, in your particular case. Set the valve to the specs for your engine, not the model.
    John Kubiak
    Las Vegas, Nevada
    Sea-Doo Tech 13736
    Jun 2005
    Virginia Beach
    9
    Quote Originally Posted by John Kubiak
    Thank you so much!!!
  1. Replies: 2
    Last Post: 07-10-2006, 06:49 PM
  2. Seadoo Rotary Valve damage - Advice needed
    By jdpowerski in forum Sea-Doo
    Last Post: 09-17-2005, 11:14 AM
  3. Rotary Valve timing
    By JimboJones in forum Sea-Doo
    Last Post: 08-09-2005, 10:50 AM
  4. Rotary Valve Timing
    By skooter in forum Sea-Doo
    Last Post: 07-01-2004, 09:21 AM
  5. rotary valve timing
    By louis914 in forum Sea-Doo
    Last Post: 06-01-2002, 12:01 AM
