98 gp1200 carb setting
  • 98 gp1200 carb setting
    Can somebody give me the stock settings for a 98 GP1200 carbs.
    Thanks a bunch!
    Vince
    Low speed screws: 1 1/4 turns out (#1,2), 1 1/8 turns out (#3)
    High speed screws: 1/2 turns out (#1,3), 7/8 turns out (#2).
      Thanks Bryan - another question - 1, 2, 3 is the Mag, CTR, and PTO cylinders respectively right?
      Vince
        Correct.
          Since you giving good info, could you tell me the stock max RPM's for this boat?
          Lets see if I can't get it dialed in.
          Thanks for your help Bryan.
          Vince
            Are these settings the same for a 99?
              Stock RPMs are just above 6800 RPMs.
              Yes the specs are for 97-99.
                Are these carb. settings the same for a '97? Also would they be different if using Vortex flame arrestors?
                  Yes they are the same for the '97, and yes you will need to adjust out for the flame arrestors.
                    Re: 98 gp1200 carb setting
                    What size needle & set, and spring for stock carbs?
                      1.2 N&S and 95 gram spring = Stock
                      Making nervous wrecks of innocent fish outside of No Wake Zones everywhere!
                      • #12
                        and what about the pop off psi?
