1995 750 SLT takes on 6" of water in 10 minutes
  • 1995 750 SLT takes on 6" of water in 10 minutes
    picture this each time I've used it this year it takes on water quick. Yet you can put around the marina with the seat off and not find anything.
    All I can think of is that some water was trapped in over the Winter, as this started with the first ride of the season.
    Any ideas?
    I'm not really family with PWCs. Oh BTW I've owned this machine for aproximately 6 hours of use and have logged aprox $2500 in repairs in three visits(it spent most of the previous season in the shop, so I'm avoiding the shop.
    So I guest anything could be the problem.
    Re: 1995 750 SLT takes on 6" of water in 10 minutes
    so when you put it in the water in the marina there is no obvious leak with the engine not running?
      run it with the seat off and see where the water is coming from. on that boat, it prolly leaking at the ex man gsk, or the headpipe gsk, or it could be the cooling line from the pump has been rubbing on the lower exhaust support and worn a hole in it. sounds like you've got a big hole in the cooling system. :(
        Re: 1995 750 SLT takes on 6&quot; of water in 10 minutes
        hi my slt700 did the same thing the hose from the pump to the motor y tee rubbed on the bottom of the hull and leaked in side the ski but will not leak that much until you ride hard then will flood the inside
          Thanks for the advice. In my looking around I still haven't figured out where the water is coming from yet.
          But I'm watching that hose like a hawk.
            get a flush kit connector so that you can connect your garden hose to it and run the motor and check it for leaks at home.while running it with the garden hose and the engine running move the cooling hoses inside the motor compartment around to find holes in a hose.. check the hose clamps to the cooling hoses because they eat away at the hoses. check also to see if any hose clamp is loose with a screw driver and tighten them up. you'll find the leak, it's a pretty big one by your description.
              Put water ino hull not anough to hurt anything while on trailer and see if you can see were it leaks from
                also, where the bilge lines go up to the top of the hull, then back down, there is an 'L' connector. It has little tiny pinholes. Those pinholes must be clear or it will siphon water back into the hull.
                  Back your trailer into the water(so the ski is almost completely in), Secure the back of the boat to the trailer and keep the front tied down like normal. Start it up, warm up for a few like usual then hit the throttle. make sure it's secure try this with the seat off and you might see the water coming in. Has the impeller/pump been off?? maybe it's not completely sealed and with time and back wash it's filling. Tat is if it's not the hoses. or a cracked thermostat housing(plastic part on bottom end of cooling rail.
                    Thanks! With all this I have a great action plan. Work has had me buried but I'm thiking I'll be able to shake loose and get doen to the river this week and see what I can see.
                    Thanks for youe expertise!
