just ordered a 3 outlet fuel pump and i have only one question. does the return line on the carbs stay connected or do i cap off those as well? i saw the diagram in the tech help forum about how to connect the inlets to the pump, but cant find anything about the "other" lines that return fuel to the gas tank.
fuel pump question.
Re: fuel pump question.
Hopefully someone more knowledgable will write too, I am only personally familiar with the add-on pump. But:
hopefully they will send you a digram and instructions on it. The return lines probably will stay connected, there is a plastic restrictor in most return lines right after the carbs, so it'll keep the pressure to the carbs, but excess will go back to the tank.
