Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Aug 2005
    Great Lakes State
    10
    Default Polaris Airbox Upgrade Kit 1992-1995
    I have 2 Polaris 1995 SL750s. One of them has the "open air flame arrestor" kit issued by polaris installed on it (replaced the clamshell/snorkel design) I had that one done back in 1997 by the dealer. At the time the mechanic told me he "re-jetted the carbs to allow more fuel" and then he showed me how to adjust the fuel mixture on each carb to make sure the fuel mixture was right (based on plug color afte riding it with a load on it). That ski has run awesome for the 8 seasons...and went from 48mph to 52mph.
    My question is this: I bought the same kit for the other SL750 (still has the stock airbox on it, all original) and don't know much about carb jetting. The flame arrestor/airbox kit looks pretty simple to install, but I don't know what size jets I need, which jets, or how to install them. Is it necessary to put new jets in? The Polaris dealership that did the great job on my first ski is no longer selling Polaris.. And the Mechanic is long gone... Any other dealership I talk to wants TONS of $$$$ to do it.
    any help would be greatly appreciated!!
    Oct 2004
    Arkansas
    173
    Default Re: Polaris Airbox Upgrade Kit 1992-1995
    I've been looking for an "open flame arrestor" type to replace my stock air box.
    Give us some paticulars....where you bought it, prices, pics etc
    Thanks.
    Aug 2005
    Great Lakes State
    10
    http://www.parkeryamaha.com/index.as...D&ProdID=24770
    It's the factory issued improvement kit used to reduce water ingestion when ski is flipped over. It was reccomended to me back in 1997 by the mechanic I used to deal with regarding my 1995 SL750 (1st one). It also improves air flow and cc volume to carbs. It's similar to all 96+ airboxes.
    Oct 2004
    Arkansas
    173
    Thanks......Even the price is reasonable.
    I was looking in Dennis Kirk and I thought the prices were pretty high.
    Thanks !
    AL D
    Aug 2005
    Great Lakes State
    10
    No problem... good luck!
    Mar 2005
    Wenatchee, Wa
    60
    put the new jets in. you should have got a installation instruction sheet with the kit. i found a copy from the last one i did. polaris says install the102.5 main jets on the 750 engines. and the105 main jets on the 650 engines. why the larger jets on the 650 im not quite sure. low speed jets stay the same. update your fuel pump while your at it if it has not been done yet. dont want to melt downyour engine from lean carbs/ jetting or lack of fuel from weak pump. i and others use the 5 sided mikuni high volume pump. it has two outlets,one goes in original fuel rail inlt.other goes inbetween mag and center carb. you will need to install a tee. some people install two tees between pto and center between center and mag carbs, and block off origional inlet.some use triple outlet pumps duel single outlet pumps and some use threesingle outlet pumps the choice is yours. do not remove the fuel line restricter in the return fuel line. good luck. check your metering diaphrams and fuel filters while you have it all apart,and pop off if you have a gauge. you can buy just the diaphrams by themselves from your seadoo dealer or your yamaha dealer about 18,20 bucks needle and seats about the same price,make sure they are the same size, i believe 2.0. or you can wait a couple days and get complete kits from sbt,
    Aug 2005
    Great Lakes State
    10
    Thanks for the info Frisbee. Also thanks for bthe info on the fuel pump situation. My 1st ski that's had the kit since '97 still has the orig. fuel pump on it. It was just relocated from the intake to the hull via the mod. bracket thets in the kit. Can the mikuni fuel pumps use that same bracket?? Thanks again!
  8. #8
    Mar 2005
    Wenatchee, Wa
    60
    the kits i have installed were on slt model. i just zip tied new pump to the side of the hull instead. with the fuel lines and electrical that were allready there. i sold my wifes sl-700 this spring. i have not been completly forgiven yet. what a fun boat. but people were driving it wrecklessly. so i sold it. bought here a yamaha wave venture. its to slow,it wont spin, i want a faster boat she says. yup! I says.
  9. #9
    Oct 2004
    Arkansas
    173
    Do you really have to change the jets when you install this up-graded air box?
    I just hate to mess with something that is working OK.
  10. #10
    Aug 2001
    Las Vegas, Nevada
    1,220
    Quote Originally Posted by dierdorf
    Let's see you just changed the airflow characteristics of your carburetors...they are now capable of flowing more air...If you do not increase the available fuel, you will be runing lean, and could very well seize the engine. At that point your ski would no longer be "working OK".
    I would also verify wether or not you need to adjust the pop-off to compensate for the lower restriction of the open element F/A vs. the original design.
    John Kubiak
    Las Vegas, Nevada
    Sea-Doo Tech 13736
  1. Carb rebuild kit 1998 Polaris SLTH
    By DaBank in forum Polaris
    Last Post: 07-03-2006, 10:19 PM
  2. 1995 Polaris SL750 - Flush Kit?
    By Sam in forum Polaris
    Last Post: 07-26-2005, 11:38 AM
  3. Polaris is OUT of the PWC business!
    By Technical Support in forum Polaris
    Last Post: 09-02-2004, 11:56 AM
  4. POLARIS 2003 models - hot of the press
    By Airborne in forum Polaris
    Last Post: 08-01-2002, 01:12 AM
