1994 Tigershark Barracuda
I checked the service manual and the net and I still don't know what the third line from the fuel tank is supposed to do.
According to the manual
The outermost hose is the supply line from fuel tank to the fuel pump on the carb
The innermost hose is the return line from the fuel pump on the carb to the fuel tank.
The middle hose (which is T'ed) is the question.
One line from the T has a check valve and then a fuel filter at the end
This I assume is the air inlet to the fuel tank (thus the check valve)
The second line from the T (is a mile long) and also has a check valve only allowing flow back to the tank
What is this for ?
Where does it attach to ?
Dennis
What is this for ?
Dennis
