How the heck do you remove the driveshaft, impeller and jet pump? I've got the Venturi off but the pump, impeller, and shaft are almost glued on :). I took off the four nuts holding the pump on. Any ideas? I'm trying to take the engine out.
Argh... Removing the driveshaft, impeller, pump...
My Gallery for my Seadoos: Pride & Joy
Condition:
Pride is flat out not running. Compression: 1. 137psi 2. zip
Joy is stripped down to nothing.
Not exactly living up to there names yet.Tags: None
Re: Argh... Removing the driveshaft, impeller, pump...
k I'll try that. BRB.My Gallery for my Seadoos: Pride & Joy
Condition:
okay I tried that and knocked it loose but not free. IT will wiggle but wont come out. Am I missing something? I took the clamps off of the shaft by the flywheel...My Gallery for my Seadoos: Pride & Joy
Condition:
ah. Probably, I saw loctite on all the bolts... be back.My Gallery for my Seadoos: Pride & Joy
Condition:
Did you remove the pump hoses on the inside of the hull??that will keep it from comming off..so slo gettin faster <A%20HREF=[ bunny.jpg? postalaka y165 albums i5.photobucket.com alt="Image hosted by Photobucket.com" img]http:>
There is a splined joint connection at the pump and at the pto. Both should slide off but not always. Disconnect the rubber boot at the pto that holds it onto the driveshaft. If you search the forums you can get more info on pulling the driveshaft/ pump off.
have had similar problems w\several ski's ,96gti,94gts,97gts,etc,etc. made bracket out of 2x4 and 3/8 piece of steel, designed to fit 140 mm pump and have waited days for it to break loose by just turning on jig for days at the time. they can be stubborn buggers ! good luck! Trey.
I GOT IT... ACTUALLY, my dad got it... but I was there. We took the chain from the trailer and used the bolts from the venturi and made a loop. Then took a metal pipe and pryed it over the bumper. Came right out.
Thanks for the info! Engine is out and now I can begin to clean the inside of the jet ski from all the oil.My Gallery for my Seadoos: Pride & Joy
Condition:
