The intake grate on the ski was ripped off...pulled front two studs out of the hull and broke the grate...back two studs and back part of the grate were left in tack. We put on a new grate and epoxied new bolts on...same thing happened..epoxy apparently not strong enough...Can I drill through the hull and use bolts and nuts inside the craft to hold this grate on...I do not have the craft to look at it now....Does anyone have one? If I drill the front holes through the hull underneath can i get to the area on the inside of the hull to mount a plate and nuts to hold the bolt on? I know that it is close to where the water pickup is or towards the rear of the craft. Anyone ever do this yet? Thanks!
