Results 1 to 6 of 6
    Jul 2005
    north bay
    13
    Default 1993 GTS tangled rope around shaft now won't go past 5-10 mph
    My 1993 GTS sucked in the tow rope and it tangled around the shaft. Got all of the rope out but now the ski won't go past 5-10 mph if I try to go faster all it does is rev... HELP please.
    Nov 2002
    New Jersey
    40
    Default Re: 1993 GTS tangled rope around shaft now won't go past 5-10 mph
    Sounds like you damaged the impeller, pump and or wear ring!
    :beer :emoticont
    Jul 2005
    north bay
    13
    How could all that be damaged with just the rope tangled around the shaft? How do I fix it, is it a hard job?
    Mar 2005
    Wenatchee, Wa
    60
    put it on a trailer or boat stand. crawl under it with a creeper and flashlight.look really good . does not take much to cause cavitation. pine cone ,twig, little millfoil around shaft or in grate, shredded plastic garbade bag. rock in grate or in stator . i have experianced all of these from pwc,berkley jets to outboard jets out duck hunting.they are a huge vacume cleaner sucking up any thing in their way. good luck.also look at the clearance between impellor and wear ring. should be quite even all the way around without being excessive.or touching one side and not the other, witch might indicate bent shaft.
    Jun 2002
    Groton, CT
    57
    Is it actually cavitating or did you spin the the teeth on the drive shaft? That's what happened when I sucked a rope up.
    Jul 2005
    north bay
    13
    Crawled under the ski, everything looks good, I jamed the impeller with a chunk of wood and tryied to spin the PTO to see if the teeth were stripped, but it held tight, any other suggestions?
  1. help! got rope caught around shaft
    By pwint in forum Sea-Doo
    Last Post: 10-25-2007, 12:05 AM
  2. Rope around shaft, now starter doesn't turn over?
    By brad@jclayton.com in forum Yamaha
    Last Post: 09-27-2007, 07:41 PM
  3. 1993 Gts
    By northbay111 in forum Sea-Doo
    Last Post: 05-01-2006, 04:57 PM
  4. 1993 sea-doo GTS trouble starting
    Last Post: 07-25-2005, 01:21 PM
  5. 1993 Gts Driveshaft Coupling
    By ctpwr3 in forum Sea-Doo
    Last Post: 07-13-2005, 01:06 PM
