I have a 1999 GSX Ltd 30 hrs on engine.....did a compression test (145PSI) on both cyclinders. One of the spark plugs become really built up with carbon after one tank of gas.....the other is fine.......It starts bogging and eventually has no power (I assume becuase only one cyclinder is firing)....is the one cylinder runing rich? I'm using NGK BR8ES spark plugs.
I am also noticing a lot of more water in my hull when compared to my 1999 GP 1200. The Sea Doo has a bilge pump and it keeps the water at ~3" but if the bilge pump stopped working I think I would be in trouble......Should I be so dependant on the bilge pump or do I have a problem with a seal or something. The GP doesn't have a bilge pump and is generally keeps dry. I am missing one of the two plastic tubes that hang out the back of the jet pump.
