It is apparent that the stock single outlet pump is lacking in the flow department. To combat this most either add a supplimental pump or replace the stock pump with a 3 outlet pump. I have a 94 sl750, and a 96 raider 1100. The raider has a single outlet mikuni pentagon pump. Both ski's in stock form use a fuel rail setup for both supply and return. I have never heard of, or experienced a problem with the yamaha setup.
My question is this. If the stock polaris pump was replaced with a single outlet pentagon pump, would the fuel rail setup provide adequate supply, or is there another inherent problem with the fuel rail setup? I noticed that the raider has the supply and return on opposite ends of the carb rack where the polaris has them both on the same PTO end. Does this make any difference?
Any feedback is appreciated.
