Having trouble getting a ski to run correctly (93 VXR PRO 700cc), it bogs after 1/4 throttle. Im concerned about its temperature. When on the hose and idling, the cylinder towards the stern is cool, probably 120 degrees, plenty enough for you to touch, while the forward cylinder is like 180 degrees, which scares me a bit is this normal? I think its the thermal sensor limiting the ski, but if it was it would limit at a certain RPM correct?
The ski on land bogs at 1/4 to 1/2 throttle, and when on full throttle, the RPM's hit 7 grand (not sure if its an electrical failure causing the tach to read wrong), and it bogs tremendously, also misfiring. I cut the thermal sensor off and tried keeping the wires not touching and touching and it made no difference in the bogging problem. I think its electrical, because if it was the carburetor it would change performance right? Could it be my CDI?
Also, this ski has no Rev Limitier that Im aware of, I tried putting it in water, and it bogged at 1/2 throttle, or 3 grand RPM
