Found that water has been getting in. It has corrosion and all kind of white spots, but I cant see where the water is coming from. all the o rings are there. I gonna replace the stator. When I put it back together can I use some rtv sealent around the cover, starter, and stator plug?? Maybe this will help to keep water out.
I removed the stator cover and......
Re: I removed the stator cover and......
water can come in though the starter or anyother gasket . the only way to keep it 100% dry is to keep the water out of the ski . you can seal it with the right stuff . but remember even a submarine leaks :-)PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
