What would cause the edges all around the impeller to be worn down in one day???????? I have new driveshaft, new bearings and seals in pump, and was a brand new impeller..... my clearance between the impeller and the housing was about .254 mm on average. I started hearing a funny noise (which i assume now was the impeller grinding down) when I was doing 180's and then later it kept getting worse and started making the noise when i jumped waves. Now i have lower bottom and top end.... HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
impeller problems!!! again!!!!!!!!
Re: impeller problems!!! again!!!!!!!!
nope... if i beach it I am always extremely careful to clean any sand out before operation. The only thought I had was possibly the engine not being bolted down quite securely or something.... maybe a bad engine mount... any ideas?
Does anyone know the torque to tighten the impeller to so it does not come off? this could be the problem...... also, I am planning on using a high strength locktite on it. Is this good, or does anyone have any better ideas? or possiblities why this is happening??? If a wear ring is worn, could this cause cavitation that would make the impeller hit around the edges??
Nothing makes an impeller hit other than a swollen wearring/housing. Tighten the impeller as tight as you can get it - it self-tightens in the water.SBT Tech Support is here to help with your problems.
Originally posted by ericfoxDoes anyone know the torque to tighten the impeller to so it does not come off?WE WILL NEVER FORGET!
_____________________________
'94 Polaris SL750
Ocean Pro Extended Ride Plate
Mikuni Dual output Hi volume fuel pump
Skat Trak D-75 SS 6 Vein Pump
Skat Trak 13/18 Swirl Impeller
If the mount was so far gone that the impeller was effected, the through-hull carrier and engine would have been toasted first.
The steel liners pressed against the aluminum housings develop corrosion between them, that builds up and presses the liners inwards. It happens mostly from lack of care/washing.SBT Tech Support is here to help with your problems.
