I have a 1997 Yamaha Waveblaster II 760. After running it for about 10 minutes the temperature light flashes and the engine kicks into protective mode allowing me to limp back home. The jet intake is perfectly clear. The funny thing is that after the engine goes into protective mode, if I shut it off for 10 seconds it runs just fine for another few minutes. Could the temperature sensor be bad? If so, where exactly is the temperature sensor located? I have another ski I can take the temperature sensor from but need to know where it is so I can swap the two. Also, if after swapping temperature sensors, the problem still exists, what else can I do to troubleshoot this problem?
Thanks in advance.
Thanks in advance.
