1998 gsx starter cuts off
This topic is closed.
  • 1998 gsx starter cuts off
    When trying to start my 1998 gsx limited, I hold the start button and the engine will turn for some time and stop. I have to press the start button again to get it engine to turn. Eventually it will start, after a few tries. The starter bendix was replaced. It had several broken teeth. It worked good for 3 days after it was replaced, and now has same problem again.
    Thanks for any suggestions,
    Fred
    Re: 1998 gsx starter cuts off
    Go over every ground wire and make sure the terminals and cables are not corroded. Install a brand new battery.
      Thought I'd let you know what I found. The +12 v signal leaving the mpem to engage the starter solenoid was going off and on. I assume the mpem is bad for that signal. I just added a relay the was energized by the ground from the start button. then I just sent +12 v to that relay to engage the starter relay.
      Fred.....
        Thank you - SBT Mgt.
