94 GTX, pour gas into carbs, starts and runs, but only until fuel in carbs runs out. Replaced pulse pump and checked the vaccum from crank case, seems to be working well, but no fuel coming from the tank. Pulled the filter, everything looks good, blew through fuel lines but not getting fuel to carbs. After I pulled fuel filter, by cranking the engine, no fuel went into the fuel filter bowl, had to suck some in to fill this up but still not going into the carbs.
Questions
Is there anytype of fuel pump like on yamaha's.
Whats the best way to get the carb's off on this boat. The motor is a 650.
I do have good compression in both cyclinders.
Help
Thanks,
Mitch
Questions
Help
Thanks,
Mitch
