Re: compression 96 GTX
Update I took the ski out this weekend and I am still having the same problem the ski runs great up to about 5700 rpms then after I open it up past 3/4 throttle it just shuts right off. I turned the low speed screws out a little and still had the same problem I also turned the high speeds out a little. When I pull the plugs they are dark brown/ black so I know it is getting fuel and oil. Could scratches in the RV cove cause the ski to just shut down at high rpm? I am running out of things to try here. The ski starts right back up it will start back up before it even comes to a stop with out removing the lanyard. Any info would be a great help. Thanks
