Results 1 to 7 of 7
Thread: cleaning carb
    Aug 2005
    8
    Unhappy cleaning carb
    Hi have a pair of 96 kawasaki sts 750's and am going to get ready and clean my carbs in jet skis and am wondering do i need a carb kit and if so what kind or what exactly do i need to do also is the fuel water seperator supposed to have gas in it or water or what.....Thanks
    21,545
    Default Re: cleaning carb
    If you see water in your filter/separator it means you have water in your fuel system and you need to empty it out, and get the water out.
    Carbs can not be cleaned - you always need a kit. Keihin CDK2 carbs: http://www.sbtontheweb.com/Merchant2...tegory_Code=35
    Aug 2005
    8
    Thanks i will get them, but i should see fuel in there right or should it just be empty..
    21,545
    Yes, if they were in use there will be a little fuel in them.
    Aug 2005
    8
    OK understand mine is getting full to the top is that ok do i have to keep dumping it out or no????? sorry bout bothering you with these little question.....
    21,545
    Sorry - I thought you were talking about the carbs. If you don't see water in the separator, you don't need to do anything.
    Aug 2005
    8
    Ok ran them in the water 1 did great all day no probs the other one was hard starting then finally did but after a min started bogging down real bad especially after giving it gas then died and would not start up and if did soon as you put gas on it it died what could that be and do i have to take it in to a shop or can i fix it myself
  1. Internal carb filter cleaning
    By DrewNJ in forum Sea-Doo
    Last Post: 11-30-2005, 12:29 PM
  2. carb cleaning
    By Blue Lake in forum Yamaha
    Last Post: 09-02-2005, 10:10 AM
  3. carb cleaning
    By stevepaulus in forum Sea-Doo
    Last Post: 09-20-2003, 11:42 PM
  4. Cleaning out Carb filters
    By DougK in forum Sea-Doo
    Last Post: 08-15-2003, 07:35 PM
  5. Tech 20 - Detailed carb cleaning
    By Bryan Glynn in forum SBT Videos
    Last Post: 10-08-2002, 10:07 PM
