I am trying to put the carb on the new motor. I quess on the old motor there was two lines that came off the carbs to seperate places for them on the engine. On the new engine there is only one place to put the hose so should i T the two lines together. and run them to the same spot. Will that work????
Carborator Question with new sbt engine
Re: Carborator Question with new sbt engine
Originally posted by brad2510I am trying to put the carb on the new motor. I quess on the old motor there was two lines that came off the carbs to seperate places for them on the engine. On the new engine there is only one place to put the hose so should i T the two lines together. and run them to the same spot. Will that work????
