Re: gas flooding engine
The shaft is tapered to increase the surface area. Smooth surfaces under pressure can create an unbelievable bond. I work with extruders that run in excess of 15000psi. This is how we seal our dies. just a smooth surface.
You should put some ink on the shaft, install and torque the flywheel and then remove it. See if the ink is missing in most places. If not one of the tapres is damaged.
