I am reassembling my engine and I'm not sure how far the flywheel should go on the crankshaft. Should the flywheel go far enough for the reduction gear to be engaged or does the reduction gear slide out to engage the flywheel? I lubed the end of the crankshaft lightly as instructed by the manual, but the flywheel is going on with much difficulty.
flywheel assembly
