Results 1 to 4 of 4
    Oct 2004
    Arkansas
    173
    Default '95 SL 750 Jet Pump Preventative Maintenance ?
    Is there any Routine or Preventative maintenance measures that need to be taken on a SL 750 (jet pump) other than keeping the shaft Center Bearing lubed ?
    I "searched" for an answer but nothing showed up.
    Thanks !!
    Jul 2005
    North Jersey
    390
    Default Re: '95 SL 750 Jet Pump Preventative Maintenance ?
    Keep the PTO and seal carrier lubed up and you should be fine. It dosn't hurt to pull the pump at the end ofthe season and check the prop bearings and seals either.
    Jun 2002
    Charlotte NC
    1,868
    Every 4-5 years change the bearings and seals before they fail.
    Oct 2004
    Arkansas
    173
    Thanks ...I was thinking along the same time frame......also !!!
  1. polaris 750 fuel pump
    By ericfox in forum Polaris
    Last Post: 06-12-2021, 01:46 PM
  2. Jet Pump Leak tester (P/N 295 000 085)
    By 97seadoospx in forum Sea-Doo
    Last Post: 10-20-2005, 03:05 PM
  3. Repainting the Jet Pump?
    By 96gsx in forum Sea-Doo
    Last Post: 10-17-2005, 01:59 PM
  4. Jet Pump Bearing loose
    By PYRO in forum Sea-Doo
    Last Post: 10-17-2005, 07:33 AM
  5. 1995 750 ZXI Jet pump
    By jsp in forum Kawasaki
    Last Post: 07-08-2004, 11:50 PM
