Results 1 to 5 of 5
Thread: Need Some Help
  1. #1
    Joined
    Dec 2004
    From
    EVANSVILLE,IN
    Posts
    46
    Default Need Some Help
    I Have A 96 Sea-doo With A 587 White Rebuild From Sbt Totaly Rebuilt The Carbs. Pop Off Set At 28.5, New Fuel Lines,clean Filter,fresh Gas And New Oil. New Spark Plugs Ngk-br8es Have Tryed Many Sets.ran Fine For About 20-to 30 Min On Flush Kit At 10 Min. At A Time 45 Min. To Cool Down.took To River Started Fine And Ran Fine For About 1/2 Mile And Then Died It Did Not Lock Up.but Would Not Restart For Nothin. Back At The Shop Checked Plugs And Replaced With New Set Checked Fuel Filter Ok.comption Is 135psi In Mag: Cyl. And 136psi In P.t.o. Cyl. Looking Down Into The Carbs With A Light I Can See A Mist Of Fuel As It Turns Over.trys To Run For About 3 To 5 Sec. Then Nothing. Good Hot Spark+ Fuel+ Comp= Run ???? Good Batt. Stays At 13+ Volts While Cranking Over....
  2. #2
    Joined
    May 2005
    From
    Los Angeles(Hollywood)
    Posts
    425
    Default Re: Need Some Help
    are you premixing or oil pump?
  3. #3
    Joined
    Jun 2002
    From
    Charlotte NC
    Posts
    1,868
    Put an ounce of premix down each carb and see if it will stay running longer on that. If so then you know it is a fuel system problem.
  4. #4
    Joined
    Nov 2003
    From
    Glendora, CA
    Posts
    6,846
    Is it possible that you spun the magnetor flywheel ? Sheared the woodruff key?
    Bill O'Neal <br>
  5. #5
    Joined
    Aug 2001
    From
    Las Vegas, Nevada
    Posts
    1,220
    Quote Originally Posted by REDLINE
    Good Hot Spark that occurs at the proper time to ignite the air/fuel/oil mixture + Fuel (fuel and oil)+ Comp (air)= Run ????
    John Kubiak
    Las Vegas, Nevada
    Sea-Doo Tech 13736
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
