I installed the 3-outlet mikuni fuel pump on a Polaris SL650 and now it runs like it has too much fuel. Some times it won't rev up past 1/2 throttle and if you're idling and punch the throttle sometimes you can kill the engine.
I've read on here that "you can't feed too much fuel to the carbs" and that no jetting is necessary to change with this fuel pump. Isn't it putting out more fuel pressure than the stock one, so shouldn't it require smaller jets?
