Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    Sep 2005
    Miami
    23
    Question 787 Rotax Motor Rebuilt the top end but motor wont start
    I recently (and stupidily) ran my 1800 Challenger without oil. I totally wore out the pistons and it's rings on one of the engines (its a twin). Anyway I bought a piston rebuild kit and installed everything as the shop manual states (btw I have never did this before). After I tighten everything to torque specs and plugged in all the hoses I crank the engine and it wont start!! Very frustrating after working for days on it. The engine turns , the spark plugs have sparks, the fuel is good (since the other engine works) battery is ok. I didnt check the compression becuase I dont have one of those testers ( will buy one ). After trying to crank it for a while I shot starter fluid and that didnt work either. A couple of times it started but immediately died. Not sure what the problem is. BTW when i took the spark plugs off to check them. I noticed the oil was a grayish color. One more so than the other. Any suggestions. I need help on this because I can't afford a sea doo dealer mechanic!!!
    Feb 2004
    New Jersey
    2,601
    Default Re: 787 Rotax Motor Rebuilt the top end but motor wont start
    do not use starting fluid . if you tore up your pistons with no oil iam sure the crank is not feeling to well . did you check it ? also did you check the rotory valve ? if not check it now . if the plugs are gray and fould it will not start the gray is dirt from the rebuild , you need to confirm the rotory valve is in time and spinning and that you have good compression , if so then put a new set of spark plugs in .
    Nov 2003
    Glendora, CA
    6,846
    Check your fuel lines to be sure they are not reversed and also make sure you connected the pulse line to the cases and carbureators.
    Aug 2004
    Olympia, WA
    3,629
    Make sure you fuel selector is set to ON. A lot of these boats have one selector for each engine.
    Dan Solie -
    04 RXP (the "Instigator")
    94 xp (freestyle mods)
    95 xp (faster than the 94)
    Sep 2005
    Miami
    23
    When I checked my pistons and saw that I tore them up I also checked the crankcase by checking if I ran it dry. I opened the plug on the side and it still had oil in there also it turned fine so I assumed the crankcase was fine. The rotary is indeed spinning. The spark plugs are brand new.
    21,545
    You didn't inspect anything. You needed to break it down and properly inspect every inch if the crank and bearings.
    Sep 2004
    INDIANA
    152
    In your first post you didnt mention doing anything to the cylinders! did you ? Do a compression test and let us know the numbers.
  8. #8
    Sep 2005
    Miami
    23
    I rehoned the cylinders gave it a nice crosshatch pattern. The ring end gap is .030in ( I know it is a little big but according to seadoo the gap can be up to .039in on a wear limit should work I guess?? ) I will do a compression test shortly will give you my numbers.
  9. #9
    Sep 2005
    Miami
    23
    I checked the compression it was about 150psi on both cylinders. Anything else I can do before I break it down to the crankshaft?
  10. #10
    Jul 2004
    chicago
    160
    Try new plugs....Check all the fule hoses again, and pulse line...
  1. 96 rider 1100 top end gasket questions
    By 96waveraider1100 in forum Yamaha
    Last Post: 08-22-2005, 05:04 PM
  2. '95 SL750 Loss of Top End Power
    By pseudonym in forum Polaris
    Last Post: 08-12-2005, 11:20 PM
  3. 97 SL 900 No top end.
    By thetadgt in forum Polaris
    Last Post: 08-10-2005, 05:23 PM
  4. New Top End???
    By 99gp1200 in forum Yamaha
    Last Post: 10-04-2002, 09:46 PM
