1992 SP will run at times, then won't. Has good fuel delivery, but no spark or very weak spark when it won't run.
Switched out coil in electrical box, no change. One coil lead shows very bright light with 12 volt test light while cranking at times, then dim light while cranking at other times, then no light at times when cranking. The other coil lead has good ground all the time.
I do not have a Bombardier Ignition Tester, but have a multi meter.
Any ideas of what to do next would be very much appreciated!
