Results 1 to 3 of 3
  1. #1
    Joined
    Sep 2005
    From
    Centennial, Colorado
    Posts
    2
    Question 92 SP no spark (at times)
    1992 SP will run at times, then won't. Has good fuel delivery, but no spark or very weak spark when it won't run.
    Switched out coil in electrical box, no change. One coil lead shows very bright light with 12 volt test light while cranking at times, then dim light while cranking at other times, then no light at times when cranking. The other coil lead has good ground all the time.
    I do not have a Bombardier Ignition Tester, but have a multi meter.
    Any ideas of what to do next would be very much appreciated!
  2. #2
    Joined
    Feb 2004
    From
    New Jersey
    Posts
    2,601
    Default Re: 92 SP no spark (at times)
    unplug the rev limiter if that helps replace the rev limiter { black with red strip or white from the MPEM }
  3. #3
    Joined
    Sep 2005
    From
    Posts
    2
    Thank you. Will post results when I get down to the lake week after next.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Losing all hope 96 XP, No SpaRk
    By zubie96xp in forum Sea-Doo
    Last Post: 04-27-2009, 01:31 AM
  2. cylinders
    By K6jet in forum Yamaha
    Last Post: 08-12-2005, 08:47 PM
  3. Replies: 29
    Last Post: 06-01-2005, 10:18 PM
  4. Turns over but no spark
    By mike3000sx in forum Yamaha
    Last Post: 05-08-2005, 01:51 AM
  5. 1997 spx new motor no spark
    By seasoned in forum Sea-Doo
    Last Post: 03-18-2003, 01:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
