99 Genesis HELP!!!
  • 99 Genesis HELP!!!
    I bought a 99 polaris genesis the weekend. It has a blown #3 piston and sleve. I bought a new cylinder and piston and it all went back to gether fine, I also checked the other pistons and the look great and have great compression. my problem now is that it run VERY rough, if it in the water it will only go to 3850rpm's very rough . out of the water it will rev up to 7200, but it runs rough untill it hits about 4500 and then raps out fine. it is the injected version. Any help would be greatly appreicated, I have searched other threads to no avail.
    Shawn
    Re: 99 Genesis HELP!!!
    did you find out what blew the cyl ? if not it will blow again and if its running bad i would check fuel pressure first .
      The ring broke and just tore up the piston and the sleve. I took off the fuel line to the injector adn it seamed to have a lot of pressure. If the emm was out would it run at all??
      thanks
      Shawn
