Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    ADub is offline Showing off on the beach
    Aug 2005
    Houston, TX
    26
    Default Re: Won't start after carb rebuild
    Got out and properly tested the valve tonight. Sure enough, it has an internal leak.
  2. #12
    Aug 2005
    Houston, TX
    26
    Re plumbed the fuel tonight. Carb is pulling fuel, accelerator pump shoots gas, pulse port holds 25 psi vacuum, but I still am not getting fuel into the engine. I'm guessing this means I did not properly rebuild the pump?
    The fuel inlet on the pump will hold 25 psi vacuum, but only pulls 3 psi when cranking. I am guessing this is my problem.
  3. #13
    Jun 2002
    Charlotte NC
    1,868
    Put two tablespoons of premix down each carb and then hold the throttle 1/4 open and see if it will start then die. If so then the problem is in the carbs if not the carbs are not the problem.
  4. #14
    Aug 2005
    Houston, TX
    26
    Will do. Can anyone tell me how much vacuum I should be pulling on the fuel inlet with the engine cranking? Tech Support?? I do have SBT carb kits in this thing
  5. #15
    21,552
    A couple psi is all it's supposed to pull from the tank. Without seeing it I have no idea if you built it correctly - or even if you have the lines connected correctly. What fitting do you have the inlet line attatched to? What did you set pop-off to?
  6. #16
    Jun 2005
    Fox River Illinois
    15
    What are the correct locations for the supply and return lines?
    On my 94 640, I believe that the supply line is on the bottom and the return line is on the top? Is this correct?
    I'm having the same problem... it'll run on premix, and sometimes off the tank for a while (maybe 4 or 5 minutes), but then it dies and won't start again...
    I haven't checked the fuel lines or fuel filter yet (one of my next steps)
    I have rebuilt the carb, but I have no way of checking the pop-off pressure.
    -J
  7. #17
    21,552
    Start your own thread.
  8. #18
    Aug 2005
    Houston, TX
    26
    Not worried about the right lines in the right place, I have that much confidence. I have been wrenching on on vehicles for 15 years, just never a jet ski........Pop off is set at 20 psi
  9. #19
    Jul 2017
    Los Angeles
    4
    I blew into the return line but nothing happened except air came back out of the return line.
  10. #20
    Apr 2018
    Crown Point
    1
    Quote Originally Posted by ADub View Post
    30 - 40 psi
    Sent from my SM-G935T using Tapatalk
  1. Carb rebuild kit 1998 Polaris SLTH
    By DaBank in forum Polaris
    Last Post: 07-03-2006, 09:19 PM
  2. Mikuni Carb Rebuild Question
    By mase in forum Sea-Doo
    Last Post: 06-22-2006, 11:02 AM
  3. Carb Rebuild Gone Bad
    By JimZ in forum Sea-Doo
    Last Post: 09-13-2004, 03:52 PM
  4. carb rebuild kit?
    By *97GTX* in forum Questions about SBT
    Last Post: 06-28-2004, 01:27 PM
  5. ts 1oooL no start after carb rebuild
    By tack in forum Tigershark
    Last Post: 07-02-2003, 11:24 PM
