Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    ADub is offline Showing off on the beach
    Aug 2005
    Houston, TX
    26
    Default Won't start after carb rebuild
    Previous owner said it ran, but it needed a carb rebuild. 98 770R. I rebiult both carbs and now it won't start. Its got spark, but its not getting fuel. I cannot find any external leaks. Pulse line is clear, pulse port holds pressure, fuel filter and lines are clear. What else can I check? I'm pretty sure I put the pump back together correctly, but I have no idea why I'm not getting fuel now.
    Aug 2005
    Houston, TX
    26
    Default Re: Won't start after carb rebuild
    I am getting fuel coming out the accelerator pump, but no fuel is coming into the filter to replace the fuel that went out
    Aug 2005
    Houston, TX
    26
    So I have decided that the problem is that I can't pull fuel from the tank. How do I pressurize the tank or bleed the lines to get fuel up to my filter?
    I pulled the main and reserve lines, plugged them and tested the switch, it holds pressure just fine.
    Jun 2002
    Charlotte NC
    1,868
    If you blow into the return line you should get fuel out the supply line. The supply line goes to the bottom fitting on the carb and the return line goes to the top fitting. The center pulse fitting connects down onto the crankcase fitting.
    Now when you try to start it you should be getting fuel flow out of the return fitting on the carb. Unplug it for a test and check. If no fuel is flowing out and all lines are connected up with clamps and the crancase is providing pulse to the fuel pump then the fuel pump is still not working.
    Aug 2005
    Pennsylvania
    31
    Pressure testing isn't always the answer. Remember, to draw the fuel from the tank, the pump creates a vacuum in the line and the atmosphere pushes on the top of the fuel in the tank, forcing into the line and into the pump. If there is a leak into the fuel system, the vacuum may formed may be insufficient. The fuel selector valve is the high point in the system. A leak here will really kill things.
    Also, reed valves in the pump MUST sit flat and tight to the base plate. Push on them quicklygently, if you hear them seating (a small tap), they are bent, and no good.
    Aug 2005
    Houston, TX
    26
    In hindsight, I'm not sure I fully tested the selector. I will check it again tonight more thoroughly. I don't think the pump is my issue. If I remove the supply line from the carb and put vacuum on the supply line, I still don't get fuel.
    So say the switch is leaking, can I just run a line straight from the reserve pickup to the fuel filter to get it running and worry about fixing the switch later?
    Aug 2005
    Pennsylvania
    31
    Just as quick test, you can throw a vacuum gauge on the pump inlet, and see if the pump pulls a vacuum, just to satisfy yourself.
    Rather than using the reserve line directly, would it be easier to runn the engine from a very small container? If you do the reserve line thing, I wouldn't leave it that way longer than it would take to test. You might gravity feed fuel through the carb into the engine undesireably.
    Keep in mind that air has to get into the fuel tank to push the fuel out. If the inlet air check is installed the wrong way, you'll eventually have a vacuum in the tank air space, and fuel won't flow.
  8. #8
    Aug 2005
    Houston, TX
    26
    If the switch is bad, then I plan on bypassing it so I can use the ski a few times before winter, then worry about the switch in the off season. If I routed the new hose similar to the current routing so that the highest point on the hose is the highest point in the system, I don't see how it could be any worse off that it is with the switch. I am new to the mechanic side of jet skis though.
  9. #9
    Aug 2005
    Pennsylvania
    31
    Good plan, but you may still be hampered by siphon action once the hose is void of air. Siphon action will occur when the source point Gas tank) is higher than the delivery point (the carb), and the hose between is filled with liquid.
  10. #10
    Aug 2005
    Houston, TX
    26
    Gotcha, makes sense
  1. Carb rebuild kit 1998 Polaris SLTH
    By DaBank in forum Polaris
    Last Post: 07-03-2006, 09:19 PM
  2. Mikuni Carb Rebuild Question
    By mase in forum Sea-Doo
    Last Post: 06-22-2006, 11:02 AM
  3. Carb Rebuild Gone Bad
    By JimZ in forum Sea-Doo
    Last Post: 09-13-2004, 03:52 PM
  4. carb rebuild kit?
    By *97GTX* in forum Questions about SBT
    Last Post: 06-28-2004, 01:27 PM
  5. ts 1oooL no start after carb rebuild
    By tack in forum Tigershark
    Last Post: 07-02-2003, 11:24 PM
