I recently bought a 95 GTX 650 that was only running on one piston. I found no compression in the front cylinder. I pulled the top half down and found the piston coming apart on the front cylinder and the piston looked fine on the back. You could see witness marks on the top of the piston where parts of the ring got up there and were banging around. I've worked on 2 cycles before that went lean and burnt a piston before but there were not signs of a lean condition on this motor . The plug looked brown, the top of the piston was damaged but did not look white. I bought a top engine kit, honed both cylinders and replaced both pistons. It started and ran great but after about 15-20 minutes it started running on one cylinder. Checked compression and again none on the front. Same thing started happening, pieces of the ring came apart and got on top of the piston.
My question is, does the oil injection feed each carb independently and if so could I have a lack of oil to one cylinder or do you think it's a lean condition?
Any help is appreciated. Thanks
