Results 1 to 2 of 2
    Jun 2005
    Melbourne, Australia
    249
    Default Blue or red loctite for engne bolts
    Just wondering what strength loctite i should use for the engine bolts (ie: Crankcase, inside cylinder, top of engine bolts). I was thinking that blue loctite should be enough. Do i need to get the stronger (red) loctite instead? (ie: Is there any chance of bolts shaking loose if i use the blue loctite?)
    Thanks.
    21,545
    Default Re: Blue or red loctite for engne bolts
    You should not be building an engine without an OEM service manual or experience.
    Blue is correct.
  1. 787 Motor Head Bolts
    By reiverson in forum Sea-Doo
    Last Post: 04-10-2007, 03:35 PM
  2. Simple question about engine bolts
    By Ozzie Seadoo in forum Sea-Doo
    Last Post: 10-01-2005, 06:42 AM
  3. LOCTITE ON CASE BOLTS
    By Technical Support in forum Yamaha
    Last Post: 06-17-2004, 01:08 AM
