I am having difficulty starting this ski. I had the carbs and fuel pump overhauled in the spring. It did just fine all summer long and now it won't start. I have checked the compression and got around 150 on both. I have good spark from the plugs. It seems I am not getting enough fuel pressure from the pump. I disconnected the output line from the pump and cranked the engine. it didn't appear to me to have sufficient pressure. Is it possible the check valves are leaking? Is there an electric fuel pump available for this ski? It's a good ride and would like to be on the water again. Please advise me as to what I need to do to get it running again.
2001 Seadoo LRV fuel pump
