Results 1 to 10 of 10
    Aug 2005
    CT USA
    37
    Question Running an engine WITHOUT water? How long?
    I was just wondering how long anyone would say an engine can run without water???? 20 seconds? 1 minute? Don't do it at all?
    I never do this, but am just curious since many say you can run for under 30 seconds or so when making changes or something. I personally never run for more than a few seconds without water to get all of the water out of the machine after I turn the hose off.
    Just curious, do the engines get hot and blow up right away? or could an engine run for a little while before getting too hot?
    No flaming! I am just curious:)
    May 2005
    Los Angeles(Hollywood)
    425
    Default Re: Running an engine WITHOUT water? How long?
    honestly i'm learning. but i woud def say that once it reaches normal temp is when u stop runnign it immediatel. just like an automobile. theres a certain valve taht opens up for teh radiater cooling once the engine reaches running tempetures w/o cooling so that the engine can get to normal riding performance.
    Jun 2005
    Lake Charles, LA
    74
    on average 15 secs.
    Nov 2003
    Glendora, CA
    6,846
    You can start and run a watercraft motor for up to 30 seconds without hurting it.
    Radio,
    You are talking about a thermostat, but a thermostat has a hole that allows water through it to keep the water circulating through an engine until it reaches the theromstat's opening tempature which aids in the engines ability to reach operating tempature faster and sustain the minimum operating tempature of the engine.
    May 2005
    425
    thats what i thought as well. but i guess teh concept is the same? maybe? hehe.
    21,545
    Quote Originally Posted by Bill O'Neal2
    Except Yamaha 4-strokes - 5 seconds max.
    Nov 2003
    Glendora, CA
    6,846
    Yes. I should have qualified that as to two stroke motors only.
  8. #8
    Jul 2004
    Chicago
    14
    On 4 strokes, what happens after 5 seconds? Even if you have a cooling system like in a SD 4-tec?
  9. #9
    21,545
    The Yamahas can overheat in a hurry. They have very intricate internal cooling systems. The Sea-Doo's can go a little longer, but still need external cooling and circulation pretty soon after starting. No ski is designed to run without active cooling.
  10. #10
    Sep 2004
    florida
    118
    The 4-tec cooling system runs through the ride plate allowing the water to draw the heat from the coolant,so if it's not in the water once the coolant heats up you will overheat aswell .
  1. Replies: 1
    Last Post: 07-25-2006, 02:12 AM
  2. engine sucking up water
    By postransformation in forum Polaris
    Last Post: 06-04-2006, 09:58 AM
  3. Water in Engine after roll over -help
    By sk187 in forum Sea-Doo
    Last Post: 09-05-2005, 11:35 PM
  4. out of the water engine running
    By wthile in forum Yamaha
    Last Post: 09-02-2005, 06:02 PM
