$3000 later XPL still not running Part II
  • #16
    Re: $3000 later XPL still not running Part II
    All I know is that 1) I took him my xpl because it was bogging REAL bad He told me I had a VERY Dirty fuel filter and needed a carb & fuel tank cleaning and I paid for the service. He test drives all of his repair jobs on the lake by riding it around. After I picked out the watercraft and after riding less then 2 hours the thing would only go half speed and check compression and it was ok. I took back to the tech and after 2 weeks he said I found the problem "dirty fuel filter again" and then he starts claiming he can not fully clean a fuel tank without taking out motor and pull out the fuel tank. He suggest I clean out my fuel filter every 30 min of riding. So I go to the lake and after 1 minute of idle speed the motor dies and I pulled the plugs and notice that water is shooting out of one cylinder and my compression is 20 psi on the cylinder on that cylinder. I called him back and he states water from the fuel tank caused that damaged.
    • #17
      If the fuel filter gets clogged it can cause the cylinder to run lean and damage the piston/cylinder, probably why you now have 20 psi in that cylinder... :(
      • #18
        Man, save yourself the hassle from taking it to another dealer and do the repairs yourself. If you need help doing it, we can help you through it. Like I said before, I am in Charleston if you need some help.
        SHOOTER
